September 25, 200917 yr I did do the fold the end of wire over thing, that is what was cutting my grips. I have not looked for the Mechanic's tape.........maybe worth a look.
September 26, 200917 yr i spray a bit of GT85 in, they slide on super easy. never had any bother yet.. http://www.jejamescycles.co.uk/gt85-spray-...-item44505.html
October 3, 200917 yr ooer first post.. the problem with grips is they need to be wet to get on and bone dry to stay on. i like the dry type no glue needed. so the best way i found and works every time is spray clutch and brake cleaner it evaporates real quick like a degreaser so spray loads in the grip and push on as fast as possible. the grip is bone dry inside in a few secs and will not move. add wire if required Edited October 3, 200917 yr by zoolord
