Engine Removal
Following on from dragging clutch reply just about to remove engine from 97 250 techno for main bearings any tips or things to watch out for? (At first look it seems that the engine comes out from the left ie clutch side but I would welcome any comments.
Thanks
the engine does not come out from the left it drops out from the bottom you have to take the bash plate off. and when you go to take the skid plate rubber off if it is stuck on give it some gentle heat and it should come off without taking all the paint off like on a freind of mine's techno
