Swm 240 Shock Legnth
Hello, I would like to know if the rear shocks are suppose to be 14 inches long? Also, are they suppose to be mounted in the front mounting hole or the rear. There are two holes for mounting and my shocks which are 14 1/8 inches long are mounted in the rear position.
Thanks, Scott
Hi shock length should be 360mm (14 1/4 inches) fron centre to centre
Use the forward bottom shock mount only.
Thanks for the reply. I asked because I wasn't sure if my fox shox could be rebuilt. The shafts have small pitted rust spots. I believe I have found a source for them though.
