09 Scorpa Sy 250 2t
As far as I know all you have to do is remove the fame lug on the kickstart side. This gives you a lot more room and makes it easier to replace the rubber connector on the back of the carb which is normally very tight.
Haven't done it myself but I know it is a Berket approved mod. and I know a rider who has done it.
Darren
Darren
100 % correct !! :huh:
Darren
frame lug??...whats a frame lug?..how about a photo...............massso
Hi Masso!
sorry ive have been a bit vague,been busy :huh:))
A frame lug is the metal bracket on the frame that the sub frame screws to.
On my bike the BOTTOM sub frame lug on frame,kick start side,hade been removed.
This means you only have to remove 4 screws undo the carb rubber and slide subframe and airbox and silencer off in one,very easy :huh:))
Hope this helps??
If you give me you email i will take photo of frame and send it you tomorrow??
Regards
Benz
benz,
just out interest, have you ridden a standard sy 250???? how does the new beast compare???
Hi Masso!
Hope this helps??
Regards
.....great....still clear as mud to me !.........heres e-male adress....bob@bmasse.com ..Thanks
