Front Brakes Are Binding And Squealing
Just Fitted new brake pads to the front of my Beta, for some reason they are binding and making a high pitched squeal.
I tried slackening off the lever adjustment but that has not made any difference.
Any sugestions?
Take the reservoir cap off and using a screwdriver gently pry the pads apart to push the pistons in to the caliper, replace the reservoir cap and pump up you lever,
Gday, before doing the above make sure you have a small amount of free travel at the leverbefore it begins to push the piston. This is vital.
Cheers,
Stork
Cheers,
Stork
What he said
Well done Stork
