michael martin Posted March 11, 2010 Share Posted March 11, 2010 Did anyone come up with a wiring diagram to install the KDS36100 100A controller on a new 36V Quote Link to comment Share on other sites More sharing options...
samandkimberly Posted March 12, 2010 Share Posted March 12, 2010 I haven't yet - and unfortunately, looking at my workload I'm not going to have a chance to make one up until May at the soonest! Ah, well, better too much work then not enough, I suppose... Sam Quote Link to comment Share on other sites More sharing options...
samandkimberly Posted March 12, 2010 Share Posted March 12, 2010 I should add, BTW, that it's not too hard to figure out. Just try to eliminate as many connectors as possible when you're wiring it in and check the ones you leave alone. the stock crimped ones aren't perfect. I used all waterproof heat shrink connectors. Sam Quote Link to comment Share on other sites More sharing options...
juanroberts Posted March 12, 2010 Share Posted March 12, 2010 Even a picture of the Kelley-to-OSET connectors would be a great help, or maybe forwarding the info provided by Ian? Thanks. Quote Link to comment Share on other sites More sharing options...
samandkimberly Posted March 14, 2010 Share Posted March 14, 2010 (edited) See pics below. I'll try to add some more description soon, but I thought getting them up here was a good start. Note that I machined the tabs off either side to fit the controller between the frame rails - this is only one of many ways to fit it. The speed control pot isn't used, neither are the black/white wires coming out the controller. All the connectors are Walmart heat shrink waterproof connectors - over in the trailer section here in the US. Sam Edited March 14, 2010 by samandkimberly Quote Link to comment Share on other sites More sharing options...
