April 4, 201016 yr Hi Folks can anyone out there give me an idea of whats involved in replacing the gear selector shaft on a 08 4t, and point me to where i can find a diagram or anything that might help, is it an engine out job? Many thanks in advance Whiz Edited April 4, 201016 yr by whiz
April 4, 201016 yr Give Lampkins a ring and speak to one of the mechs - they will give you all the advice you need. The exploded parts diagram might be of use. http://www.betatrialuk.com/content/view/162/90/
April 8, 201016 yr If your talking about the shaft the shifter lever fits on, i've done a couple of them, it's pretty easy and straight forward. The shaft goes thru the motor from the clutch side. Takes 30-45 minutes to do.
