April 13, 201016 yr Hello all Over the past week my scorpa has been experiencing running problems. It starts up fine and runs. However once it has been rode for about 5-10 mins (once its warmed up) it start to miss fire and looses all power. I am unsure if it is electrical or fuelage problem. I have removed the stator but that looks okay but i am sending it to get checked over to be sure. Has any body else had this problem? or does anybody might know what it could be? Any help is appreciated Thanks Ant
April 13, 201016 yr ONE ASSUMES YOU CHANGED OLD SPARK PLUG FOR NEW AND CLEANED CARB& FILTER? MAYBE JUST BLOCKED FILTER OR DUFF PLUG IF NOT DOES IT MISS UNDER LOAD THIS USUALLY INDICATES ht PROBLEM
April 13, 201016 yr Also check the fuel tank vent....you might be losing fuel flow once enough fuel has been used to create a vacuum in the tank.
April 14, 201016 yr Author thanks for the replies. I changed the plug which still did not cure it, so i changed the plug again just to make sure it wasnt a faulty plug. Ive also cleaned the carb out numerous times. Its strange because once the bike cuts out, its starts again without trouble abd rides for 5-10 mins again before it starts to miss, and rev all over the place. I can keep it going but i have to constantly rev it. I will check the fuel breathers when i get home form work tonight. Thanks again
April 19, 201016 yr Author I sent my stator away to WCW and they said it was faulty, ive had it re-wound and re-fitted it. However the problem still exists, ive checked the tank brather and everything is okay there. Also 1 of the manifold bolts where loose, ive tightned that buit havent rode it yet. Anymore ideas people? thanks
April 19, 201016 yr thanks for the replies. I changed the plug which still did not cure it, so i changed the plug again just to make sure it wasnt a faulty plug. Ive also cleaned the carb out numerous times. Its strange because once the bike cuts out, its starts again without trouble abd rides for 5-10 mins again before it starts to miss, and rev all over the place. I can keep it going but i have to constantly rev it. I will check the fuel breathers when i get home form work tonight. Thanks again What carb is on it, how long have you had the bike........has it been running well for a while then suddenly crap, did you have an ''off'', before it ran crap, what fuel and mixture are you running, is there a good seal between the carb and the airbox and reed-block, is there a kill switch on it ?????????? A bit to check, but well worth it !
April 20, 201016 yr Author What carb is on it, how long have you had the bike........has it been running well for a while then suddenly crap, did you have an ''off'', before it ran crap, what fuel and mixture are you running, is there a good seal between the carb and the airbox and reed-block, is there a kill switch on it ??????????A bit to check, but well worth it ! Hi houseape1000 It has a Keihin carb on it, it has been running fine for the last 8 month. I havent fallen off it neither. I am using 1/50 oil ratio as this is what the previous owner ran it on. The seal to the airbox is fine, i need to check the reed block, i havent checked this as yet. There is also a kill switch on it which is working. It feels as tho the bike is running out of petrol. Thanks for the advice i will give all this a check
April 27, 201016 yr Author Its finally sorted! It was the carb. the floats where set up wrong, i must of put it back together wrong when i had the bike in bits! Thanks for all your help Ant
