mooregas Posted May 3, 2010 Share Posted May 3, 2010 Ive got an ignition problem with a 280 06 pro, theres no spark, theres a live from the stator to the voltage reg(yellow wire) and from the voltage reg(yelow wire) to the cdi, and all the earths are good, but i carnt get a live at the lead! a new cdi is Quote Link to comment Share on other sites More sharing options...
ggjord Posted May 3, 2010 Share Posted May 3, 2010 are you sure the thin bl/white wire from the cdi is good as they are made short and easily break off. Quote Link to comment Share on other sites More sharing options...
mooregas Posted May 4, 2010 Author Share Posted May 4, 2010 yeah all conections are ok, thanks anyway Quote Link to comment Share on other sites More sharing options...
bigfoot Posted May 10, 2010 Share Posted May 10, 2010 It may be worth changing out the regulator first. I've had two of these fail in the past on a 2004 and 2006 pro. Both times I appeared to be getting an output but obvioulsy not enough under load. Quote Link to comment Share on other sites More sharing options...
