Rear Brake Losing Pressure
I'm not sure what is causing the seal to come apart I end up with little bits of rubber in the fluid, it came with dot 4 so thats what I have been using
Mine was like that as well, possibly a sharp edge on the hole to the resevoir hose, which could waer away at the lip on the seal?
Edited by jonny042
I think thats normally good logic, but after what you've already done, It couldnt hurt to try somthing else. Sounds like a real head banger of a problem. Did you inspect the used Master Cylinder for burrs? If you get a another new one, I would be tempted to excersize it a few hundred times and inspect the seal for damage. I know several folks mention they honed or polished there MC, but havent done that myself.
I have put on 2 new and 1 kit the bore looks fine, just changed to dot 5 per Jacks recommendation ,we will see!!!!!!!!!
