May 30, 201016 yr Hi all, just come in from the shed..... my project TY175 forks, are not what they seem! The bottoms are from the TY range (probably ty175) but the fork stantions (Outside dia size are 46.5mm) do not have the standard screw thread fork cap tops they have instead a wire circlip and a plug. does any one know if any other fork legs will fit, or can I buy new stantions? from ABE? with oil in them they seemed very bouncy! I invested in some legs from a DT175 (early C model?) but the stantions are too short....plus I cant get the bolt loose from the bottom of one leg. No amount of swearing has budged it! I'm wondering whether to rechrome these legs and experiment with the springs and oil weights to get near a decent feel Cheers Steve
May 31, 201016 yr You've gotten me confused here, Ty175s would have stanchions about 34mm. Are you sure your 46.5mm diameter is not the outside of the sliders?
May 31, 201016 yr You've gotten me confused here, Ty175s would have stanchions about 34mm. Are you sure your 46.5mm diameter is not the outside of the sliders? Tony 27 is right,46,5 that is from a modern MX bike. Chrs:Mike
May 31, 201016 yr Author Tony27 and Ducman 46.5 is the outside oil seal size, my mistake, starting to think to far ahead. Fork outside diameter is 30mm just measured. Does this give me any options? This bike is becoming a labour of love.
May 31, 201016 yr Tony27 and Ducman46.5 is the outside oil seal size, my mistake, starting to think to far ahead. Fork outside diameter is 30mm just measured. Does this give me any options? This bike is becoming a labour of love. Yeh that would be better. Chrs:Mike
June 1, 201016 yr Best thing you can do is get a set of Ty250 twinshock forks off ebay, it's meant to be a fairly common mod
