stevie78 Posted June 28, 2010 Share Posted June 28, 2010 Hi there can anyone tell me where this is ment to fix to as mine is cable tied to the frame . cheers stevie Quote Link to comment Share on other sites More sharing options...
jse Posted June 28, 2010 Share Posted June 28, 2010 Hi there can anyone tell me where this is ment to fix to as mine is cable tied to the frame . cheers stevie My 02 Pro had the reservoir attached up by the airbox intake, much like the older models and I made a bracket to move it down under the tank like the newer Pros. It's easier to see and service. There is a spring clip that the reservoir bolts to that attaches to the cylinder brace in the newer bikes, if you look at a newer bike you'll see how they go and your GG dealer should be able to get one for you, I doubt they cost much. Jon Quote Link to comment Share on other sites More sharing options...
stevie78 Posted June 28, 2010 Author Share Posted June 28, 2010 cheers Quote Link to comment Share on other sites More sharing options...
