Can Anybody Explain...
gasgas694
when i was out on my 2005 gas gas the weekend i had been on it for about an hour had a break and then fired it up after checking it was out off gear i kicked it off and it was as if i had started it in gear the bike started doing a donut with me holding on to the handle bars, after i manage to hit the kill switch i tried again and the same thing happened can anybody explain this...
was the clutch lever pulled in when it started,could be the clutch not clearing,due to hydraulics or clutch plates sticking together. I have had the same problem when the bike has not run for awhile. Cheers Malc
