July 21, 201016 yr I need to remove the spring from my rear shock - TY250R Mono (the one with the remote reservoir). The spring can only move an inch or so up the body when the collar is removed due to the lug for the reservoir hose. I assume the base of the shock must come apart somehow but cant see an obvious way to do it other than trying to clamp the damper rod and unscrew it, but theres hardly any room as the spring is in the way. Anyone done this before ??
November 5, 201015 yr I have the same issue and no solution, did you get it sorted in the end? Surely it must come apart no?
November 6, 201015 yr I'll expand a bit here so y'all know the why's and what for. I recently gave my ty250r it's first wash in my ownership after riding it 4-5 times. I'd noticed a squeek from the backend and was thinking of dry linkages needing a re grease. What I found though was quite horrific, (gotta love secondhand old bikes) the rear spring had snapped near the top and had previously been welded I have a suitable looking replacement (not really wanting to redo the weld tbh) and just need to get that shock apart to fit it. Any help much appreciated, this is the only thing stopping me being out on the bike.
November 6, 201015 yr I haven't looked at my TY shock so not sure if it will work. But know on other bikes I use a spring compressor like this to disassemble the rear shock... http://www.denniskirk.com/jsp/product_catalog/Product.jsp?productId=p282533
November 6, 201015 yr Author Compressing the spring isn't the promlem. Removing the spring is the issue. Still not had any success and have asked several people
November 8, 201015 yr I spoke to my local trials guru today and was told that these shocks are *untakeapartable*. This seems a bit strange as they 'look' like quite an advanced unit what with the remote resi and range of adjustment. Oh well, none on ebay at the mo and I want to ride it tomorrow so am in the process of modding a Yamaha TTR shock which is now fitted and just needs pre loading up to suit. *non word alert
