Beta Evo Cdi Mapping Method
As far as I know the only adjustment is a two position switch located on the left side frame backbone plastic near the front. Position 1 offers better torque at low rpm very lienier midrange and topend power. Position 2 offers softer low rpm torgue and stronger midrange and topend power.
Hi, Liviob.
Thank you for information.
Yes, Evo has two position of ignition timing. however,
I would like to change all of ignition timing profile by using PC which is like factory.
Maybe I need PC, Software, serial cable and battery.
Does someone know shop are offering these units?
You might have to get a vortex programable ignition. I dont know if one is adaptable. http://www.vortexcdi.com/
This is reply from "Vortexcdi".
Thankyou for your enquiry!
Unfortunately all the CDI's are very specific to the models they are
designed for.
We do not have a CDI for this model.
Do you know other programmable ignition CDI vender?
