mike31270 Posted August 22, 2010 Share Posted August 22, 2010 would someone please tell me how to change the fork oil and how often it needs doing on my 06 250. I have read the waynes corner section but that is from an older bike and my fork are not the same. Also what oil should i use. Please help Quote Link to comment Share on other sites More sharing options...
copemech Posted August 23, 2010 Share Posted August 23, 2010 Suffice it to say that if you have a good grasp on the older ones, the new ones('06-up) are similar yet different. Left Leg= spring side! Drain completely and refill. Right Leg= damper side. Remove lower bolt, drain leg, extract damper unit throu top and continue to pump it about 100(00) strokes till you get all the old oil out or your measures will be off! Reassemble, pour oil in top whilst working the new oil in the same way before you cap it. 385ml left. 370ml right. High quality 5W fork oil. Getting old oil out the damper is the most critical part. Frequency? Annually, depending upon how much you ride. Cheers, Quote Link to comment Share on other sites More sharing options...
sherco_man Posted August 25, 2010 Share Posted August 25, 2010 Does anyone know the order in which the spring and spacers go back in? Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted August 26, 2010 Share Posted August 26, 2010 This might help Fork diagram Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted August 26, 2010 Share Posted August 26, 2010 Try this...click me please ! Quote Link to comment Share on other sites More sharing options...
eastcoasthopper Posted September 4, 2010 Share Posted September 4, 2010 Try this...click me please ! That's for older '05 and back, same fork on both sides. '06 and up only have one spring, very different. Quote Link to comment Share on other sites More sharing options...
eastcoasthopper Posted September 4, 2010 Share Posted September 4, 2010 Suffice it to say that if you have a good grasp on the older ones, the new ones('06-up) are similar yet different.Left Leg= spring side! Drain completely and refill. Right Leg= damper side. Remove lower bolt, drain leg, extract damper unit throu top and continue to pump it about 100(00) strokes till you get all the old oil out or your measures will be off! Reassemble, pour oil in top whilst working the new oil in the same way before you cap it. 385ml left. 370ml right. High quality 5W fork oil. Getting old oil out the damper is the most critical part. Frequency? Annually, depending upon how much you ride. Cheers, (You might want a heavier oil if you're a heavier guy!) Quote Link to comment Share on other sites More sharing options...
comerconstructionman Posted February 12, 2012 Share Posted February 12, 2012 Suffice it to say that if you have a good grasp on the older ones, the new ones('06-up) are similar yet different. Left Leg= spring side! Drain completely and refill. Right Leg= damper side. Remove lower bolt, drain leg, extract damper unit throu top and continue to pump it about 100(00) strokes till you get all the old oil out or your measures will be off! Reassemble, pour oil in top whilst working the new oil in the same way before you cap it. 385ml left. 370ml right. High quality 5W fork oil. Getting old oil out the damper is the most critical part. Frequency? Annually, depending upon how much you ride. Cheers, Hi copemech, would this be the same for a 2010 Sherco 290? Thanks N Quote Link to comment Share on other sites More sharing options...
copemech Posted February 13, 2012 Share Posted February 13, 2012 Hi copemech, would this be the same for a 2010 Sherco 290? Thanks N Yes! Quote Link to comment Share on other sites More sharing options...
comerconstructionman Posted February 16, 2012 Share Posted February 16, 2012 All serviced including right leg seal changed all running great. Thanks for the info Copemech. N Quote Link to comment Share on other sites More sharing options...
