201 forks
I have just bought a pair from ebay and am confused! they are both a bit leaky so i will be fitting new seals and oil but one of them has about 2cms of up down movement before any spring resistance is felt! surely this is wrong. is there a diagram of the fork internals anywhere i could ave a look at? also,ebay fork seals are 35x47x7 but motohaus leak proof seals for the same thing are 35x47x10. i would like to get the seals before i start pulling them apart so i don't have them lying about in bits for ages. another also! any info on weight and amount of oil per leg would be appreciated. ta very much guys n gals.
update.i have separated the fork with 2 cms of play in it and it looks like it has 2 seals in it. is this correct? i am going to give them a good soak and clean before i remove the old seals but all seems to be going pretty well at the moment :)
well i managed to get one fork seal out (completely destroyed in the process)and there is another one underneath! i think i will just leave it there as it is doing no harm.
oh yes,the 2 cms of movement are due to the fact the spring is snapped about 2" down <_<
