ty 250 momo clutch adjust?
gaz_hay
Now I may well be wrong as I've not taken mine apart... yet. Never the less 'normal' Yamaha doings is such that you can adjust a 10mm (ish) nut on the end of the push rod in the centre of the clutch. Often you can hold the push rod steady with a cross head screwdriver. Be warned though little adjustments make a big differance.
Even if the above is not the case on your ty you can see the condition of the clutch whilst your there ;)
