battle of burwash 2 day
raga-rep
Bexleyheath&DMCC presents
BATTLE OF BURWASH May 21st & 22nd 2011
Pre 65 solo/ sidecar & twinshock championship 2 day trial..sponsered by Nicholas Motors Welling
Open to all classes including pre 65 hard route and gentleman route
Pre 65 solos/sidecars/2 stroke/Twinshocks/Aircooled mono.
If you want to ride on a fantastic piece of land (72 acres) then this is the trial that you should pencil in your diary for every year.
Situated in the beautiful East Sussex close to the famous Battle and not to far from Hastings it has easy access to the trial, just off of the A265 at Burwash common and easy link roads A21 & A22 from the M25. map and postcode TN218XA (this gets you on the right road just follow the signs from there)will be included and it will be well signposted from the main road.
It also has ample parking for motor homes and tents ect so if you are coming for the weekend then all are welcome.
I have told a bit of a porky to grab your attention in calling it a two day trial. The plan is, this being the first 4stroke and twinshock championship we have run we hope this will grow and word gets about then we can run this event every year and hopefully improve on the format. This year the idea is that we will be laying out 3 laps of 15 sections which will vary of different terrains rocks, streams, big banks ect, and on the Saturday at 12 0clock you can go out and practise on those marked out sections as much as you like. Look at it as a free practise and an advantage over the ones who don
  • 2 months later...
Sorry about that jordi.. Being the first pre67 trial we have run and with the dreaded sidecars we were a bit unsure weather we could get everyone in and out of the same gates..next year we hope to run the trial over 2days depending on observers and yes, use the streams more.
Please sign in to comment
Sign In Now
