adam1 Posted March 17, 2011 Share Posted March 17, 2011 Hi all I have just bought a 99 techno as a second bike for my sisters boyfriend to learn on, Paid Quote Link to comment Share on other sites More sharing options...
smalley250 Posted March 17, 2011 Share Posted March 17, 2011 Basically its the same engine as your Rev3 so the same oil in the gearbox. The current beta gearbox is the same as the 94 Techno all but a few tweaks. You will have rear linkage to strip n check i would assume n wheel bearings to check n brake pads. Should be bullet proof as it was the last model so should be the best of technos all be it old. Quote Link to comment Share on other sites More sharing options...
adam1 Posted March 17, 2011 Author Share Posted March 17, 2011 Basically its the same engine as your Rev3 so the same oil in the gearbox. The current beta gearbox is the same as the 94 Techno all but a few tweaks. You will have rear linkage to strip n check i would assume n wheel bearings to check n brake pads. Should be bullet proof as it was the last model so should be the best of technos all be it old. Cheers for that, just got back from picking it up. As you said it is 12 years old but not in bad nic. will check all the obvious tomoz cheers Adam Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted April 13, 2011 Share Posted April 13, 2011 at Quote Link to comment Share on other sites More sharing options...
