cabby Posted March 24, 2011 Share Posted March 24, 2011 Stripped the carb yesterday, cleaned, back together, all running fine. Today, took the bike out for a play, all running fine, then it stopped and wouldn't start again.....me thinks, out of juice. Get's home, fills her up, but seems there was plenty fuel left in her anyway. Strips carb again, puts new fuel filter in, all back together, fires it up....then lasts about 5 seconds and dies again. Kicks, it starts then dies, kicks, it starts then dies..... Any ideas ??? Quote Link to comment Share on other sites More sharing options...
borus Posted March 24, 2011 Share Posted March 24, 2011 check spark and then the stator. Quote Link to comment Share on other sites More sharing options...
cabby Posted March 24, 2011 Author Share Posted March 24, 2011 Just put in new plug, ran for a bit then cut out again Quote Link to comment Share on other sites More sharing options...
cabby Posted March 24, 2011 Author Share Posted March 24, 2011 check spark and then the stator. How does one go about checking stator ? Quote Link to comment Share on other sites More sharing options...
tonybroad Posted March 24, 2011 Share Posted March 24, 2011 is enough fuel getting to the float bowl, float valve or what trips it off may have bbeen disturbed sounds like only a little fuel is getting through just a thought if it ran ok before tony Quote Link to comment Share on other sites More sharing options...
shercoholic Posted March 24, 2011 Share Posted March 24, 2011 (edited) How does one go about checking stator ? Before you tear into the wiring loom and disturb those important ground wires. Check the plug for a spark ..even if feint. Is the plug dry or wet? Even though the carb was cleaned is the bowl full of fuel? Maybe a sticking float valve, or a vacuum in the tank. Sometimes stopping for a few minutes is enough time to fill the bowl up until the next time it runs dry, or until it creates another vacuum. What year is the bike? Didn't I read you were on a 2010. If so check the vacuum pump is pumping when you kick the bike over, ...but careful to point the outlet hose away from the exposed plug sitting on top of the cylinder head! (Sorry Tony you beat me to it!) Edited March 24, 2011 by Shercoholic Quote Link to comment Share on other sites More sharing options...
cabby Posted March 24, 2011 Author Share Posted March 24, 2011 is enough fuel getting to the float bowl, float valve or what trips it off may have bbeen disturbed sounds like only a little fuel is getting through just a thought if it ran ok before tony It's a 2010, and there is deffo fuel coming from the pump to the carb. Took the hose off from the carb and it's flowing freely into the carb Quote Link to comment Share on other sites More sharing options...
cabby Posted March 24, 2011 Author Share Posted March 24, 2011 Check the plug for a spark ..even if feint. There isn't a spark that I can see when cranking Quote Link to comment Share on other sites More sharing options...
shercoholic Posted March 24, 2011 Share Posted March 24, 2011 There isn't a spark that I can see when cranking Short of sticking your finger in the plug cap for your morning jolt, ...then give Chris Pearson a call at Splatshop as he is always really helpful, and I believe he has the stator readings, or he can give you the Bradford Motoplat info. Quote Link to comment Share on other sites More sharing options...
cabby Posted March 24, 2011 Author Share Posted March 24, 2011 (edited) Found a loose wire coming from head back to the black box behind the head, problem is, that loose wire is now a broken wire. Since put a connector in and get a spark, not much of a spark mind but more than I had earlier, still not enough to fire it in to life though. Edited March 24, 2011 by Thedbf Quote Link to comment Share on other sites More sharing options...
copemech Posted March 25, 2011 Share Posted March 25, 2011 Poor earthing on the CDI could have had some adverse reactions in it in the electricks! Think I may start there! Good news is that is cheaper than the other parts! Quote Link to comment Share on other sites More sharing options...
cabby Posted March 25, 2011 Author Share Posted March 25, 2011 Each time I remove then refit the carb it starts, but only for a few seconds then dies ??? Quote Link to comment Share on other sites More sharing options...
cabby Posted March 26, 2011 Author Share Posted March 26, 2011 Got it fired up today after removing the kill switch, then after a few seconds it dies again, dies in a manner that is different to what it might if it was fuel starvation, for example, if it was struggling for fuel it would stutter/splutter etc etc then cut off, this just revs fine for a short time then just dies... Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted March 26, 2011 Share Posted March 26, 2011 Must be stator surely, best get the meter out! Quote Link to comment Share on other sites More sharing options...
legaleagle Posted March 26, 2011 Share Posted March 26, 2011 No local dealers you can take it too? Stators are expensive - especially if your not 100% sure it might not be the problem. Quote Link to comment Share on other sites More sharing options...
