March 27, 201115 yr Did you reverse the vacume and supply lines on the fuel pump? See if it will stay running on a separete (elevated fuel supply.) Just thoughts.
April 3, 201115 yr Author Did you sort it? Well....it's running again, nothing really found though tbh, the Stator wires were rubbing against the frame bolt although not grounding out, a wiggle of some other wires and it ran again and a tightening up various earth wires. As I say, it's running again but not convinced we've solved the problem, but again, thanks for your help
