TL250 Honda rehab
Fergie - An excellent Idea to machine down an old sprocket and save $75 (everything on ebay is around 'plus $20' to get it from US to NZ . I'm happy to keep to the 520 chain upgrade (good chain and front sprocket is OK). However - and I'm going only from dead reckoning here as I haven't any reference to a measurement of exactly how dished an OEM sprocket is - I think the spacer needed might be close to 2cm or 3cm. I don't know exactly as I don't have an original sprocket to compare it with. A large gap could also mean that the sprocket bolts out of the hub wont be long enough. Good idea none the less. I will measure the space needed once my ebay swing arm (USD$115/one woman owner/never been twisted/all threads good/ all bearings round) arrives in a week or three time. Thanks. Ross
  • Replies 94
  • Views 76.2k
Most Popular Posts
  • Sorry, it's been as while. Work, a new house, kids etc have all got in the way of riding, let alone restoring the TL. Anyway the Fat Girl is back from the workshop where she has been hibernating.
  • Nice update on your build Ross. Great weekend at the Ihatove......I've been wearing a huge smile all week. Cheers Trev (black Honda special)
  • The Saga continues ! We will make these old Honda's work and look cool !!!!!
Looks to be a good 3/4"
Thanks for that. At that distance it makes sense for the sprocket to bolt to the spacer - hence four new bolts in the photo- while the spacer users the standard nuts (that fit to the bolts out of the hub).
Edited by Ross Brown
The TY250 sprocket was only dished about 3/16 of an inch. I guess machining the old sprocket won't work for the TL250.
Just waiting on my order from BJRacing now. Due on thursday.
Sooooo close!!!! I cant wait to ride this old girl!!!!!!! :guinness:
I spent about a year on getting mine to this point:
Not an easy restore, parts are indeed tough to find.
Wow very nice!!! I debated going full bore on this one. But I decided to keep it a "rider" for now. Maybe someday...it was very tempting when it was just a frame and motor sitting on a stand! :thumbup:
It took a year because I spent all kinds of time looking for parts... NOS fenders, NOS exhaust, NOS side covers. It's easier to find Rocking-horse $hit...
Enjoy the bike they're great riding bikes.
It is ALIVE!!!!!!!!!!
It did not want to run off choke at 1st. Coughed and snorted and then cleared out. Seems to be purring good now. What a tractor! :P
Need to tweak my front fender a bit as its hitting the frame. The side panels are far to brittle to ride with. So need to ghetto-fab something up for them.
Steering feels funny to me...sorta wants to flop over to full lock. Sorta got used to it but need to mess with rear pre-load and maybe raising the forks in the trees????
Edited by sherco29
I see you are getting excited for Crooked River too Shane!!! :lol:
Ghetto-fabbed up some side panels out of some recycled uhmw plastic I had laying around. Turned out ok...for a rider!
Used T nuts in the lower grommets to bolt to. And then for the top front I used a long bolt with a barrell nut that I thread a shorter bolt into to clamp it against the tank. Right through the grommets.
Worked pretty slick.
After bending my fender bracket to level my fender I found I probably have it on the wrong way round...o well its on! :wall:
She is running good. Still not happy with the steering. Its a pusher and likes to flop to full lock...think I need to jack up the backend a bit more...
Edited by sherco29
hey,
i think i figure what reply to use.
yes,i am getting ready for Crookedriver.went riding today.plenty of sunshine and warmth on the coast.the trails were not to muddy.
had fun.
you can drop the forks in the triple trees.see if that helps.
see you next Friday.
later.
Shane
Ya, maxing out the preload on the rear shocks helped...lil more would be good though! Its soooo top heavy compared to my Montesa LOL I may just need to get used to it more! :guinness:
Sherco forget about 'maxing out the preload on your rear shocks' to get it to steer. Just go out and buy a swingarm from a thumbnail photo like I did...
I went to look for my new mudguards at the post office today. The mudguards had not turned up after almost three weeks since ordering from the UK. But the replacement swingarm had just come in. The clean grey one on the left is the OLD swingarm. Note the weld marks on the left hand tube from a previous owner's patch-up work half hidden under the new grey powdercoating. This is the reason I did not risk applying heat and straightening it. Just in case the earlier welding came un-stuck. So on the basis that a fix-on-a-fix might be more trouble that it is worth I went shopping on the web. But surprise, surprise. The shock mounts have been altered. IMG_5859.jpg
The shock mounts have been reinforced and raised 35mm. I didn't spot this alteration when I looked at the For Sale thumbnail. Caveat Emptor. To be fair to the seller, a US parts firm, they probably didn't look that close and realise it wasn't stock. Anyway, its here on the other side of the world now. It is straight and on the plus side, it will help sharpen the steering using a standard-length shock.
I will fit it tomorrow and hopefully - fingers crossed - it will all line up.
Of course, with all that gusseting and extra steel my TL will now be even heavier!
TL's are only good til you ride something better...and then you just gotta love it for what it is. Only wish mine was street legal.
