suzukitc120 Posted April 6, 2011 Share Posted April 6, 2011 Hello Ive just aquired a scorpa blue gauard model 2005?, and would like to know which way the 2 wires go onto the thermostate in the radiator bottom or does it not matter, Im also missing one of the air filter element clips from the air box lid has any one modified or found a method of holding the lid on by some other method or should I try and locate another clip Thanks John. Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted April 6, 2011 Share Posted April 6, 2011 Hello Ive just aquired a scorpa blue gauard model 2005?, and would like to know which way the 2 wires go onto the thermostate in the radiator bottom or does it not matter, Im also missing one of the air filter element clips from the air box lid has any one modified or found a method of holding the lid on by some other method or should I try and locate another clip Thanks John. The switch wires don't matter. I'm also missing a filter clip, I folded a 2mm stainless Tig filler rod to the shape and it works peachy ! Quote Link to comment Share on other sites More sharing options...
