April 21, 201115 yr Carb is a24mm mikuni it is on a BSA bantam b175 problem is when choke is on it starts and runs but then when you take it off it dies has worked fine for ages but now stopped I have cleaned inside carb aswell any sugestions please will be moast gratefull
April 21, 201115 yr If it runs on the choke and dies when you take it off then the PILOT jet is BLOCKED. Tony
April 21, 201115 yr Author Thank you is the pilot jett the one the needle goes to ? Thanks again much appreciated
April 21, 201115 yr The needle drops into the main jet and the pilot jet is located in front of the main jet. Blow compressed air through from below. Tony Edited April 21, 201115 yr by tony283
April 21, 201115 yr Author The needle drops into the main jet and the pilot jet is located behind the main jet to the rear. Blow compressed air through from below. Tony
April 22, 201115 yr Author Thanks fine now works a treat worked on my friends mini moto to thanks again
