3896 Posted April 25, 2011 Share Posted April 25, 2011 It has been bored out to a 185 and had a electronic ignition fitted and a mikuni carb any advice to make it pick up faster Quote Link to comment Share on other sites More sharing options...
chewy Posted April 25, 2011 Share Posted April 25, 2011 Flippant I know ..breed it with my Sherco. .Can you advance the timing a bit? might be all you need Quote Link to comment Share on other sites More sharing options...
3896 Posted April 25, 2011 Author Share Posted April 25, 2011 Na timing is brilliant I tried a new plug which is softer perfect now Quote Link to comment Share on other sites More sharing options...
jack_the_lad Posted April 25, 2011 Share Posted April 25, 2011 Have the ports been messed with or the piston shortened. I have bored a large number of these but the lad I do most of then for does a lot of extra work on them. Quote Link to comment Share on other sites More sharing options...
jack_the_lad Posted April 25, 2011 Share Posted April 25, 2011 Flippant I know ..breed it with my Sherco. .Can you advance the timing a bit? might be all you need You'ed get interbreading with a Sherco needs to be a gas gas. Quote Link to comment Share on other sites More sharing options...
3896 Posted April 26, 2011 Author Share Posted April 26, 2011 No I don think so it has just had a bore out Quote Link to comment Share on other sites More sharing options...
