April 29, 201115 yr Hi I get the montesa software to talk to the PTB. I had it work on a old pc but that has died. So someone please tell what the serial port setting should be ???? cheers
May 2, 201115 yr Have you a serial port RS232 on the new computer? Mine did not have one so had to buy USB to RS232 converter. With USB plugged in I search down devices being used in control panel to see what port it is in. Then on PTB software you can select what port you want to used. Select port highlighted above. If that makes sense
