May 1, 201115 yr Hello, where to buy higher bar mount? I am very stooping on bike because I am 190 cm tall. What type of bar do you use? Thanks, Petr.
May 4, 201115 yr Hello, where to buy higher bar mount? I am very stooping on bike because I am 190 cm tall. What type of bar do you use? Thanks, Petr. Bit depends upon the year of the bike, S3 make these, V-mar do some basic risers for '07 up there are others. Edited May 4, 201115 yr by copemech
May 4, 201115 yr Author Bit depends upon the year of the bike, S3 make these, V-mar do some basic risers for '07 up there are others. Thank you for advice! I have 08, but for
May 18, 201115 yr Hi Petr We have just had these made which raise the handlebars to the position that best suit you, we recommend buying a 3mm, 5mm and a 10mm set as this will give you heights of 3, 5, 8, 10, 13, 15 and 18mm so you can find the best height for you. Handlebar Riser Plates Edited May 18, 201115 yr by splatshop
