mattylad Posted May 12, 2011 Share Posted May 12, 2011 Can anyone tell me the spring rate, free length and possibly ID and OD used in a TYZ, the manual usually would have these details. Quote Link to comment Share on other sites More sharing options...
woody Posted May 14, 2011 Share Posted May 14, 2011 (edited) Just found my manual whilst looking for an Ossa one... Spring free length is 160mm Spring rate is 7kg/mm or 392lbs/in It doesn't give the spring ID or OD but somewhere I may have an old knackered shock so I'll measure it if I can find it. Not sure which year bike this manual is for now but I'm guessing the shocks were probably the same spec. It is for serial number 4GG-28199-80 according to the front cover. Edited May 14, 2011 by Woody Quote Link to comment Share on other sites More sharing options...
mattylad Posted May 14, 2011 Author Share Posted May 14, 2011 Perfect thanks, have all I really need. ID OD was a bonus!! Quote Link to comment Share on other sites More sharing options...
woody Posted May 14, 2011 Share Posted May 14, 2011 Perfect thanks, have all I really need. ID OD was a bonus!! Found the shock - OD of the spring is 80mm, the spring coil/wire thickness is 10mm so ID is 60mm. Quote Link to comment Share on other sites More sharing options...
