May 13, 201115 yr Hello,My name is Mike,recently my gearbox on my sherco 290 is playing up,get 1st and 2nd gear no problems,having dificulty finding the rest,lat time i was out on it before this happened,bike was running fine...can any one help. Edited May 13, 201115 yr by mike1969
May 13, 201115 yr sounds like a gear box strip but check the gear shaft selector where the gear pedal goes.you will have to remove clutch case first to check it.
May 14, 201115 yr Hello,My name is Mike,recently my gearbox on my sherco 290 is playing up,get 1st and 2nd gear no problems,having dificulty finding the rest,lat time i was out on it before this happened,bike was running fine...can any one help. Did you take a hard hit on the shift lever? There is a possibility that the selector return spring has broken, in which case, you do not want to operate the bike as the broken bit may get cought up in things and cause further damage. Get the clutch side off now for inspection. Spring is cheap, primary drive gears are not! Edited May 14, 201115 yr by copemech
August 17, 201115 yr Did you take a hard hit on the shift lever? There is a possibility that the selector return spring has broken, in which case, you do not want to operate the bike as the broken bit may get cought up in things and cause further damage. Get the clutch side off now for inspection. Spring is cheap, primary drive gears are not! Hey mike1969, I was wondering if you solved the problem you had with the gears. I have got exactly the same issue with my 2004 290. It seems that if after going in to 2nd I gently return the gear lever to the centre, ie push it down slightly I am able to select 3rd and so on each time I want to go up a gear. Seems like a centering spring is not doing its job properly? Just wondered how you got on.
August 17, 201115 yr Hi Ozzi Sounds like your selector spring may have broken, see here for a replacement. http://www.splatshop.co.uk/spring-for-gear-shift-lever.html
