June 26, 201115 yr hi all, i have just bought a beta 250 techno, 1999. it has a spark and is getting fuel. the carb is clean. been kicking it for two days and it wont go!!! can you help? thanks
June 26, 201115 yr Does it have good compression? If so install a new plug and kick somore. Edited June 26, 201115 yr by Liviob
June 26, 201115 yr Gday, if Compression is OK and after a new plug it still wont go, pull the flywheel off and check the woodruff key. Cheers, Stork
