sherco crank?
Is there any difference with a crank in a 2000 model sherco to a 2007 model???
Appears to be same part number!
Yeah i had a look on splatshop site at the part numbers, but i thought i'd ask on here anyway!
Yours totalled or what?
Yeah, i bought it with the motor out, the guy had fell off and it revved flat out till the big end siezed up!!
This is the parts i'm gonna order - conrod kit, main bearings and seals, small end bearing, waterpump seals, rings and all gaskets!!!
The piston and bore is perfect!
All good then, as long as you did not find the crank unserviceable. Think you will get the new style sealed main bearings, and I still highly recco the Viton crank seals from Splatshop for alcohol fuel resistance! And if doing it up, for about a tenner, you can get all new screws and nuts! Nice and shiney! :thumbup:
