branc Posted June 27, 2011 Share Posted June 27, 2011 Hi Have a problem with the clutch slipping on my tlr 200, need to take off the clutch cover off and would like to know how to take it off without affecting the decompressor etc. seems like a lot of bits have to come off to get it off. Any help here would be great. Thanks in advance Quote Link to comment Share on other sites More sharing options...
bashplate Posted June 28, 2011 Share Posted June 28, 2011 (edited) Hi Have a problem with the clutch slipping on my tlr 200, need to take off the clutch cover off and would like to know how to take it off without affecting the decompressor etc. seems like a lot of bits have to come off to get it off. Any help here would be great. Thanks in advance think you just take the cable off and your good to take the case off. no biggie, just put the same amount of tension on the cable when you refit....all good. Edited June 28, 2011 by bashplate Quote Link to comment Share on other sites More sharing options...
branc Posted July 12, 2011 Author Share Posted July 12, 2011 think you just take the cable off and your good to take the case off. no biggie, just put the same amount of tension on the cable when you refit....all good. Thanks, should have asked how to put it back on too, decompressor is a bit fiddly, had the cover on and off about 10 times before it was right Quote Link to comment Share on other sites More sharing options...
