garrod Posted July 7, 2011 Share Posted July 7, 2011 I have a 1993 Gas Gas 250 that has developed a problem, It`s quite hard to start and when it does it idles ok but if I open the throttle it sounds like it`s hunting and will not rev up then sounds like it runs out of fuel and stalls! I have a spare carb that has just been re done and it does the same with that! The spark looks ok and now I`m lost as to what else it could be! Help anyone? Many thanks. Quote Link to comment Share on other sites More sharing options...
paulmac Posted July 7, 2011 Share Posted July 7, 2011 (edited) I have a 1993 Gas Gas 250 that has developed a problem, It`s quite hard to start and when it does it idles ok but if I open the throttle it sounds like it`s hunting and will not rev up then sounds like it runs out of fuel and stalls! I have a spare carb that has just been re done and it does the same with that! The spark looks ok and now I`m lost as to what else it could be! Help anyone? Many thanks. I'd start by checking that the petrol tank breather (tube on the cap) isn't blocked - try running it with the cap off. Paul Mac Edited July 7, 2011 by paulmac Quote Link to comment Share on other sites More sharing options...
bob_m Posted July 19, 2011 Share Posted July 19, 2011 It sounds like you have a fuel delivery problem or lack thereof. The motor leans out the instant you open the throttle. Pull the fuel line off the carb and see if you get a full flow out of the tank with the gas cap on then with it off, you may have a clogged petcock or a clogged vent line or clogged fuel line. Can you rig up a temporary alternate fuel supply? Two carbs both haveing the same problem most likley rules out a carb problem. Bob Quote Link to comment Share on other sites More sharing options...
