07 Rev 3 270 clutch
Good day gents
My rev has a few hours on it and the clutch seems a bit odd
It works as it should but the engagement is over a very short range of motion of the lever
This makes slipping the clutch in a critical spot hard, you have to concentrate too much in your clutching
It seems like it engages over about 10 - 15 mm of lever motion
Any solutions to increase the range of lever travel ?
Thanks
Perform the clutch mod thats pinned at the top of the page.
I had read through that but thought it was more to solve drag and cold stick
Guess it's worth a shot and let you know if it does what I am looking for
I'd say, after having the same bike, that you have groves warn into the ctutch basket. When you take the clutch plates out - inspect the many driving faces of the clutch basket. If there are groves, even minor ones, worn into the faces then remove the basket and have an engineer mate stroke file them out with a finishing file.
And don't forget to do all the clutch mods pined here somewhere.
Ralphy
