September 9, 201115 yr Well, maybe this is the easy way out! - but I've been researching for an hour and can't find the answer to my question. What reeds fit a 2001 txt 321? I'd like to install Boyesens, but the Boyesen factory website does not indicate a Boyesen reed for the 321 (similarly to this link - http://www.ebay.co.uk/itm/GAS-GAS-Trials-Bike-Boyesen-Reeds-Pampera-Pro-TXT-new-/190559268303#ht_2080wt_907) If Boyesen does make one that fits, is there a dual-stage option? I think that I understand that if I want the best down-low torque, I do not want carbon-fiber but the "original style" reed. Is this correct? On another note, I installed a VF2 on my KDX 200, set the reeds on low tension, and loved it. Is there a way to adapt some model of the VF2 to the 321 trials engine, and would this be a good idea? Thanks for the help! Jeff
September 10, 201115 yr Not sure what is different on the 321 reeds. Might call Adrin at Lewisport of Mike at Tryals Shop. The dual stage ones are likely the ones you want, and much less costly than VF.
