September 9, 201115 yr hello! Need some advice on how to remove wheel bearings. The ones in the back wheel seem to be very stuborn and won't come out. Is there a certain method anyone uses to get them out? Any help suggestions would be mega appreciated. Cheers!
September 9, 201115 yr Tom are you heating the hub? I normally find that a good dousing with boiling water is enough and then drift the bearing out from the opposite side. If you cant get any purchase on the inside face of the bearing another option is tighten a construction type expansion bolt into the centre of the bearing where the spindle normally sits and drift against that. Most extreme option is catch a bolt or piece of bar with a blob of weld in the centre of the bearing and knock it out against that. Hope this helps.
September 9, 201115 yr Most extreme option is catch a bolt or piece of bar with a blob of weld in the centre of the bearing and knock it out against that. My preferred method, but I'm fortunate to have a welder in the garage!
September 10, 201115 yr There are some good how 2's on Trials UK's web site. http://www.trialsuk.co.uk/how2s
September 12, 201115 yr Author thanks for the help chaps! i used the trick with the 1p coin from the trialsuk website. worked a treat will definatly be using that method again.
