jdmoto79 Posted October 6, 2011 Share Posted October 6, 2011 hi i have an original 82 majesty 200 witch i need some info on. The fly wheel and crank are both scored pretty bad and keep sheering the key. From my understanding they both differ from a ty 175 so what did they use and where can i source parts. Is the piston the same as the 200 kits for the 175 if not what is it and where can i get one (i heard its a 250 piston with skirt cut down) the swing arm axle is striped i have a 175 one in there thats spaced out but gets in the way. i guess i could thread it down and cut it shorter but if i want to put the 175 back together i kind of need it And if theres any other usefully info about this bike i would like to know about it thnx jeff Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 6, 2011 Share Posted October 6, 2011 Crankshaft will be the same as TY175. Why did you think it was going to be different? Flywheel might be lightened but would have started out as a TY175 flywheel Who knows what piston is in it after all these years? You probably need to measure the bore before you start looking for a piston kit. You can buy a new or second-hand swingarm pivot bolt for your TY175 to replace the one you cut shorter for the Majesty. Suggest you post photos of the bike Quote Link to comment Share on other sites More sharing options...
jdmoto79 Posted October 6, 2011 Author Share Posted October 6, 2011 thanks for the quick reply. My dad has owned this bike since new and its the original piston. I asked him about the crank and fly wheel awile ago and he told me the fly wheel is bigger and heavier then the standered 175 and that the crank from a 175 couldn't handle it. i will post photos when i get a chance the bike is in my brothers shed Quote Link to comment Share on other sites More sharing options...
