TLR200 re-wiring problem
bhg
I have stripped out the electrical wiring on my TLR200 as I have removed the lights, ignition lock etc.
My only problem with re-wiring it are the wires from the alternator.
The Clymer manual shows a red/black wire from the alternator to the CDI unit, I don't have one but do have a black wire.
Can anyone confirm that this is the correct one?
I assume that the other 3 wires from the alternator can be removed.
I realise that the green and blue/yellow wires from the pick-up also connect to the CDI unit.
Any advice will be much appreciated.
