November 23, 201114 yr I need some help please. I have a 2011 290 factory and the engine squeals!! It came to light on Sundays trial i did 24 sections no problem then i could rev the engine but when it comes down off the revs it squeals badly, I thought it was the barrel starting to nip up but it still revs cleanly. I think its coming from the water pump and only happens when it's hot with the fan cutting in and out. The water pump has an alloy spacer to increase the volume. Could it be the impeller spinning on the shaft ??? Any ideas??? Cheers
November 23, 201114 yr It's likely the alloy after market impeller rubbing on the case - you can fix by either putting the stock one back on or taking some metal from the alloy unit with a lathe or grinder.
November 23, 201114 yr Author Thanks for the info, I'll take the water pump cover off and see if there's any rub marks on it. Cheers
November 24, 201114 yr I know this sounds obvious but you are running the right amount of oil in your fuel?
November 25, 201114 yr Hi PJ - You will probably find that the alloy impellor has been rubbing on the rough casting inside the waterpump case - We had this happen with an 09 Evo - we machined the rough spot and everything was cool. ( You won't hear the noise with the stock Beta plastic impellor) We have fitted the Costa high volume kits to other bikes without a problem, so it is likely just a casting flaw.
November 25, 201114 yr Ummm just a thought ..... before modifying the bike ..... have you talked to the importer..... he may/will have a free fix for you!
November 29, 201114 yr Author HI Dave Removed the water pump housing and sure enough there was a small curved mark around the perimeter where the impeller has touched. There is a little movement in the the impeller where it moves up to the circlip. I have fitted a small shim to keep the impeller towards the engine and removed the rough casting inside the pump housing as suggested. I am going out on it at the weekend and hopefully thats it sorted. Thanks Paul
