November 28, 201114 yr Hello as im not going to ride my bike now intill christmas time i thought i give it a good service ect first thing i want to do is change the gear oil but i would like to know which is the best but dont really want to break the bank like the nano stuff. i ride a 2002 250 sherco thanks in advance Darren
November 28, 201114 yr I use Putoline Light Gear Oil in my 2004 290. It's described as a synthetic fortified 2 stroke gearbox oil SAE 75W. You should be able to pick some up for around
November 29, 201114 yr ATF works , yet is thin and can make the clutch a bit on/off as compared to the thicker gear oils or just basic 10-40 motor oil. Seems thicker the oil, the more likely the clutck plates sticking after sitting, never trust them or you may buy the farm!
November 29, 201114 yr I only ever used motor oil in mine and never had a problem. It was cheap enough that I felt fine about changing it every couple rides. Although I'm a little out of it...there used to be stories of clutch plates becoming un-bonded and it was almost invariably when running ATF,
November 29, 201114 yr Author Cool thanks for all your advice. I did have ipone 75w gear oil in last. This worked fine and I really liked the action of the clutch My local bike dealer had some putoline light gear oil which also is a 75w so I'm hoping I will get the same sort of response as the ipone oil Fingers crossed
November 30, 201114 yr I'm running Motorex in mine. The clutch does stick for 10 seconds or so if the bike sits unused for 2+ weeks. I change the oil every 2 trials or 3-4 weeks. Cheers
