ARIEL HT5 BARREL LINER OR NICOSIL ?
huffysgas
Gday, I'd stick to the cast bore. Nicasil wont give any real advantage in the Ariel and sourcing the correct rings to use might be difficult. At the end of the day you could spend that money on other areas of the engine, eg the head.
Cheers,
Stork
Gday, you still need the iron barrel to nicasil onto so there would be little gained there. Look for other ways to save weight if that is the main goal, like drilling levers and mountings where possible, removing "excess" frame lugs etc. Good luck, it should be a nice bike when you are done.
Stork
