January 10, 201214 yr I was skeptical as well at first but thought I would try a set. I had the boyesens in and back out for comparison and had to put them back in again, cleaner quicker throttle response, smoother reving all the way through. Engine response was much smoother with them in than the standard single petal reeds, best $40 I ever spent. You can find the number on the boyesen website at this direct link: http://boyesen.com/vaf/product/list/?category=%3F&make=21&model=205&option=205&year=626 , you can also probably get someone local to match a set and provide.
January 11, 201214 yr Motomerlin in the UK have them in stock at this link: http://www.motomerlin.org.uk/product/Boyesen_Reeds_for_Montesa_315_trials_boymo
January 11, 201214 yr Author Little update. New piston arrived from Feetup this morning (great service). Fitted it this afternoon (as our electricity was off for maintenance) and the result is that it's much better. There is still a bit of a rattle so I now need to decide if I can live with this or send the barrel for replating which will cost
January 11, 201214 yr Author I would do the bearing and pin before replating the barrel. I think your both right. Will fit new ones. I'll b a dab hand at stripping these things by the time I'm done
January 12, 201214 yr Author good il fetch mine to you No worries Trickiest bit is squeezing the rings together while putting the barrel back on. Seems you need three hands!
January 13, 201214 yr im doing my top end next month just new rings bearing and pin i have noticed a slight rattle from time to time plus i want to do it need to fit those reeds before i do the top end so i can notice the difference
