Gas Gas Txt Pro Raga Just Died
hi there was wondering if some one could point me in the right direction,,,,i was riding my bike and then all of a sudden it just died,when i tryed to start the bike again it ran for a couple of seconds and then died again,,since then will not start,there was no indecation of anything wrong before this happened,i have checked fuel and air ,,,carb,,,and have put a new plug in,,,and it still will not start,,,,has any one got any ideas or has anybody had this happen to them ,,,thanks tom
If the Kill Switch checks out ok and its got Ducati Ignition have a look at the Voltage Regulator. My 2006 Pro did exactly the same. When I checked for a spark I only got one every 2-3 kicks.
can you run through the procedure for checking for a spark and the kill switch,,,do you just disconect the switch,,thanks tom
Yep disconnect the kill switch. With mine I unscrewed the Plug Cap from the H.T Lead (just in case the Cap is faulty) Hold the H.T Lead 5-6mm from the Cylinder Head and get someone else to kick it over. You should be able to see the Spark jump the gap. Hope that helps.
  • 1 month later...
the problem turned out to be a burnt out coil on the stator,,,thanks for all the help,,,,cheers
