May 31, 201214 yr Author when you cleaned the plates with a dremel did you take it right back to the steel? or just cleaned the groove?
June 7, 201214 yr yes to the metal it comes off pretty easily i think there are pics and info in the beta section good luck
June 7, 201214 yr when you cleaned the plates with a dremel did you take it right back to the steel? or just cleaned the groove? Go easy with the dremel until you've taken a look at this PDF file,it's brilliant. http://www.trialscentral.com/forums/topic/28407-the-beta-clutch-fix/ Wayne Edited June 7, 201214 yr by HAM2
June 8, 201214 yr Author i changed the plates and took the grooves off the basket and its now spot on once warm. thanks again
