bondy Posted July 15, 2012 Share Posted July 15, 2012 hi am gonner be buying some new rear shocks for my 199A the std size is 340 i was thinking of 350 only because am a heavy rider. wi dont want the bike to look to high at the rear should 350s be ok? Quote Link to comment Share on other sites More sharing options...
pschrauber Posted July 23, 2012 Share Posted July 23, 2012 Mmmh I certainly possible your question includes the assumption that when you are a heavier rider you will loose suspension travel. This is only the case if you leave the adjustment to the standard setup. you can adjust the preload on nearly every shock to fit your weight so you will not have more sag. I personal would choose the 360mm long shocks if I will have a little bit of an improvement for riding at the rear as this length just fits too. For the classic look especially when the bike stands still the standard lenght fit's best. Anyway you can use the 350mm lenght too, it is just up to you you are the owner and the rider of the bike. Quote Link to comment Share on other sites More sharing options...
bondy Posted July 25, 2012 Author Share Posted July 25, 2012 hi yes am the rider of the bike i think ill go for the 350s shocks. witch action would be best low or fast? Quote Link to comment Share on other sites More sharing options...
pschrauber Posted July 26, 2012 Share Posted July 26, 2012 Depends to your riding style, I like a rear where compression and rebound is very progressive, so very smooth at first getting harder as longer the shock compressed. Slow or fast? this depends to the impact I believe, anyway for me a more "lively" rear is my personal go. Quote Link to comment Share on other sites More sharing options...
