August 29, 201213 yr Anyone know of a way to get the rear fenders back up higher like they were new? Mine has bent down a little like they always do. Is the only solution to buy a new one? Anyone know about how much a new one is? (USD)
August 29, 201213 yr The 'works' trick is a small block of wood to wedge between the fender and the rear tyre to get the fender where you want it then... Borrow the other half's hair dryer and gently play it on the gaurd - but do be carfull or you could end up with a F1 style airfoil... Paul Mac
August 30, 201213 yr Author Thanks, I may see what I can do to give that a try. Would it work if I put the block under there and let it sit for a while? Not sure if I want to chance messing it up completely.
