sleazy p Posted September 2, 2012 Share Posted September 2, 2012 Does anybody know were I could get these front or is it main dealer only? I bought an apico kit of eBay which said it was all years but on closer inspection when it arrived the kit said 4rt 05-07 on it? my bearings are slightly larger, don't know if the shock rose joint is any different thought? Thanks Luke Quote Link to comment Share on other sites More sharing options...
jimmyl Posted September 2, 2012 Share Posted September 2, 2012 Had 315s, 05 4rt and now 09 and never noticed a difference in dog bone bearings.Never changed rose joint tho Quote Link to comment Share on other sites More sharing options...
sleazy p Posted September 3, 2012 Author Share Posted September 3, 2012 Did you just get yours from a Honda/ montesa dealer? When you put them together with a 05-07 set mine are about 1.5mm larger diameter? Quote Link to comment Share on other sites More sharing options...
jimmyl Posted September 3, 2012 Share Posted September 3, 2012 Which bearings have you a problem with. Dog bone or shock rose bearings?. Quote Link to comment Share on other sites More sharing options...
sleazy p Posted September 5, 2012 Author Share Posted September 5, 2012 It's the 2 in the dog bone and one were the linkage meets the swing arm, Iv left the shock Rose bush as it not worn out yet Thanks Luke Quote Link to comment Share on other sites More sharing options...
jimmyl Posted September 5, 2012 Share Posted September 5, 2012 All most certain the dog bone and bearing have not changed from 315 times. Is the dog bone a std one, if so try any of the reputable Montesa spares suppliers Quote Link to comment Share on other sites More sharing options...
sleazy p Posted September 5, 2012 Author Share Posted September 5, 2012 I thought that two but the swing arm ones the same, spoke to my mont dealer today will let u know what he says Quote Link to comment Share on other sites More sharing options...
ross brown Posted September 5, 2012 Share Posted September 5, 2012 (edited) For an alternative bearing solution search this Montesa forum for the thread' 4RT linkage bushes. I know they are running on an '05 and an '07. http://www.trialscen...linkage-bushes/ Edited September 5, 2012 by ross brown Quote Link to comment Share on other sites More sharing options...
sleazy p Posted September 10, 2012 Author Share Posted September 10, 2012 The bearings have been updated from 08 onward and are now 1mm in external diameter larger and 1mm in internal diameter smaller allowing for larger bearing rollers, look like Montesa only for supply at the moment... Quote Link to comment Share on other sites More sharing options...
