September 19, 201214 yr Could somebody point out what is wrong with my bike please? I've taken the carb off to clean it and on the outlet side it has a white residue in it. It continues into the boot that connects it to the reeds. It's fairly solid white like its been combusted onto it. I've no idea but it doesn't look good!!
September 20, 201214 yr Corrosion????: Oxide of Aluminum, Magnesium or Zinc depending on what metals are in the carb body Ethanol in the fuel attracts water or water leaking or sucked in some other way. Fuel evaporates leaving water to do the corrosion work.
September 20, 201214 yr Author Thanks for your replies Could this have anything to do with me changing over from regular unleaded petrol to super plus unleaded? Should I stop and go back to regular? Cheers chris
