Gas Gas 300 Txt Pro 2009, Slipping Clutch? Wrong Oil?
kristian1996
hi everyone,
just upgraded from a 2005 300 pro to a 2009 300 pro
the 2009 300 pro cost me £1500 :) it needed bits and bobs such as new tyres and the stickers where taty, but for £1500 i am more then happy with it,
went for a ride to day and found the clutch was slipping :( i believe this is down to the gear box oil?
when i bought it i tested the clutch and ran it through all the gears and it was fine, i did a oil change using 5w-30 as thats what i was told to use in my old bike and it worked great, but i think its making my new bikes clutch slip as when the bikes warm it slips much more then when i first stared it ( so oils cold )
if its not the oil what could it be ?
also what oil would you guys use?
any advise would be a great help
thanks
Everyine has their favorite gearbox/clutch oil - Autotrac II, ATF, motor oil - check that there is 2 to 3 mm of free-play in the lever., that will allow the piston in the master cyclinder to fully release the clutch fingers for full engagement. The second thing I would check is the height of the fingers on the clutch assembly. All of the manuals that are provided with the bikes have a description of how to check this measurement, as do various websites; Gas Gas factory, UK USA etc.
Hope this helps
Spencer
